Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
D2 Steering Box to GM Pump Fittings
Old Jun 20, 2021 | 10:47 PM
BoulderCharles's Avatar
Default D2 Steering Box to GM Pump Fittings
Is there a standard solution to connecting a GM power steering pump to the Discovery 2 steering box? I know this will likely require some custom hoses or a series of adaptors but can’t seem to find the steering box fittings themselves (to make a custom hose).
Thanks in advance.
Old Aug 25, 2021 | 11:17 AM
For future reference, I was able to adapt the stock high pressure line to the GM pump. I used the Dirty Dingo adapter (LS Alternator and Type 1 Power Steering Street Rod High Mount bracket for Truck Spacing), which puts the power steering pump in the right place. I had to modify the top of the bracket to lower the alternator, though.
Here are the fittings I used to mate the high pressure line to the pump.Russell AN Fitting 648060; Power Steering Adapter -06AN x 16mm x 1.5 O-Ring Seal
Russell AN Fitting 640830; Metric Adapter Blue -06AN to 16mm x 1.5 Female
90-degree 6 AN fitting
Old Dec 13, 2021 | 10:38 AM
Spam2021's Avatar
Do you have any pics of the pump installed? How are you liking it?
Old Dec 13, 2021 | 11:54 AM
Here are a few pictures. It is working really well. I like having a generic GM pump that's available at basically any auto parts store. I haven't had any leaks on the fittings, either (which I was definitely concerned about). The only tricky part is that the fittings get close to cylinder 1's spark plug so the OEM metal heat shield on the plug wire end doesn't fit. I just used some heat wrap, which works fine for me as my headers are coated.
Old Dec 13, 2021 | 12:12 PM
Spam2021's Avatar
Is your alternator right above the power steering pump? Mine is on opposite side. Looks good tho, I'm leaning towards doing this as my pump barfed up all the fluid
Spam2021's Avatar
Also which pump did you use?
Old Dec 13, 2021 | 01:28 PM
BTW, my truck is LS swapped. I don't know if this would work on the stock Rover V8.
Old Dec 13, 2021 | 01:51 PM
Spam2021's Avatar
Good to know lol 😂 thanks for the quick response tho.
Old Dec 20, 2021 | 03:03 PM
losinov's Avatar
Did you use the ACE swap kit?
I was one of the beta kit buyers which forces you to use the LR power steering pump.
The fitment of one of the hoses (high pressure I think) was very tight and concerning. Plus it would be nice to switch over to more generic/cheaper GM parts.
Old Dec 20, 2021 | 04:39 PM
No, I'm using the Marks 4WD kit as I wanted the GM 6L80 transmission. It is definitely nice to have the common GM part rather than a Rover pump.
CollieRover
Jun 28, 2017 12:11 PM
evansjoem
May 12, 2014 07:09 PM
Dan7
Feb 17, 2014 05:03 PM
losinov
Mar 21, 2011 08:57 PM
chrisusvi
Jan 29, 2009 05:54 PM
