Discovery 2 LS Conversion
#1171
#1176
Hey guys one problem that I'm having is that this stock pedal does not have enough throw to reach 100% open on my 102mm LS throttle body. Do you guys don't have any ideas on how to increase the throw?
I tried removing the stops on the pedal that are green plastic and also cutting the carpet so the pedal can move all the way to the floor. I still have about an inch to go before the throttle body is wide open.
#1177
Looks like your swap is going well otherwise!
Boostle (06-29-2022)
#1178
LS swap question. If ACE is monitoring please chime in. Found out in my Speartech stand alone LS harness that the VSS wire harness with a purple and a yellow wire that Yellow is pin 21 or high. I have been driving around with these swapped to the ECB since I was just reading when I hooked them up and Purple in most cases was high. Well assumption made an *** out of me at least. Question I have is could this cause the M and S to flash with D flashing? Also if the vehicle is running and I clear the codes I can use the Mode button normally and all is well with only the Sport light on. Tach and Speedometer work normally. WTH? Anyway I am switching them atm and will see what happens next. Does this kill my ECB? Any help is appreciated. Running an L33 and a TerraFirma 3" lift kit. Fantastic performance with just the one issue. Hope this is the issue and I haven't F'ed up the ECB. Important note is that I raised the idle to 750 in HP tuners as advised in the swap instructions and all other parameters for transmission were verified at the time. Also I would guess it wouldn't matter whch way the crank sensor is bolted to the bracket as in wires toward the block or away from the block? Besides the rod knocking on the old 4.0 there were no codes and the truck drove just fine.
So I switched the wires and soldered. No change in the issue. Another thing is if I clear the codes on the Rover ECU with the key on and engine not running the lights stop flashing and I can have the sport mode selected and light on. When I start the engine the lights start flashing and I have to clear the codes again while the engine is running. Could the ignition switch be dropping power at startup or is the crank position sensor code that I get along with all the other nuisance codes causing the problem. I get 19 or so codes from having the rover ECU not running sensors but not sure if the CKPS is supposed to be coming up. It is adjusted at .016 and everything else works once the codes are cleared. Anyone having similar issues. Beautiful swap though and will get it worked out hopefully. Don't want to have to clear the codes every time. My code reader will not access the ABS or Transmission so I cant look at those but the codes that it can access on the Rover ECU once cleared make the problem go away. ODD
#1179
What components are required for the exhaust outlet in the rear quarter panel. I really like it and wish to update mine and remove the rear resonator from the system. Same reason to get rid of the rear tail pipe clearance issues on a decent. Thanks for any information on the outlet components.
#1180
Requires some custom fab for the pipe section.
Elderair (06-30-2022)
