Discovery 2 LS Conversion
#1511
Unfortunately, ACE isn't selling kits anymore. Below is their autoresponder. I got this when I emailed him pics of my ACE-swapped Disco on the trails. He thanked me for the picture after I got the autoresponder so he is monitoring the address. As far as I know there is no other kit to adapt to the LR trans and electronics. you'll have to swap in a 4L80 along with the 5.3L and get an aftermarket dash panel. You'll lose traction control and ABS (as far as I know). It's the best that can be done right now. It's pretty clear there's a hole in the market that can be filled by some enterprising company - I wish it was me!
Thank you for your interest in our D2 kits. Due to rising coast and
supply chain issues kits are no longer available, you should look
elsewhere for your Discovery 2 needs.
This email is monitored for questions by customers who have purchased kits.
#1512
Yep. No TC / ABS with that route as far as I know. There are several people on Facebook who have ditched the engine and trans and used an LS-based engine married to a 4L80 and I think one guy used a 6L80. You have to use an aftermarket digital gauge cluster to get speed / tach / temp, etc. You also have to use a programmable transmission computer. It looks like a LOT of work.
Tach and speedometer are not insurmountable and certainly easier than the swap overall. Once those are sorted--again, easier than, say, installing a cam in the engine--traction control will work fine.
I've just done an ACE swap, and I would definitely do a 4th gen LS w/ 6L80 next time. From experience, it's far easier and more robust than any ACE kit. If anyone is thinking of a swap, be careful you will you take advice from.
--Chris
St1ck (01-27-2024)
#1513
Greetings from Tennessee. Unfortunately I found my way here after attempting to purchase an ACE kit for a customers 2004 Disco 2. What is the most logical and proven way to complete this swap with ACE going away? I really want to try to save this swap for my customer. Its my understanding that the 4l60 interferes with the transfer case, and a 4l80 is a better option. Any direction would be greatly appreciated. Additionally, a supplier of parts would be great also!
#1514
There is a adapter to mount the Rover transfer case to a to a 4L80, let me look it up and post. It does require the driveshaft to be shortened if I remember 2".
https://www.advanceadapters.com/4815
St1ck (01-27-2024)
#1515
I really don't think this is true at all. Do you know this to be true? The LS engine ECM controls the 4L80 (or 6L80 if you're using a 4th gen LS), and I wouldn't exactly describe it as 'married;' it's a factory setup, after all.. and I really don't think it requires an aftermarket gearbox control unit all; the stock shift points will work fine. So maybe let's not say those things. Moreover, you will get water/coolant temp to the gauge cluster if you run the water temp sensor from the disco--just like ACE does.
--Chris
--Chris
#1516
4L60 = significant inference with the transfer case.
4L80 = long transmission and long adapter means drivetrain is 6+ inches longer than stock, which makes for some fitting challenges.
6L80 = a bit longer setup than stock (~3.5 in), but comes with significantly more electrical issues to overcome, notably tap-shift (and shifter / programming). Gen 4 further complicates cruise control, air conditioning, park interlock, shifter indication, low range interlock …
Most that have gone these routes have lacked good integration between the GM / LR sides. Getting a swap to roll under its own power takes effort, but getting a swap to roll under its own power and work like factory is difficult.
rynoman1 (02-07-2024)
#1518
Of the seemingly infinite ways to accomplish an engine swap, the good captain has the the only solution--that's absolute. The tap shift--which everyone simply must have--can only be had with custom programming. The GM factory had zero clue when designing a truck (or for that matter, anything) to go off-road; they just didn't have the developmental budget. ECM controlled fans? Nah, go stand-alone. Drive by wire? Eff that--too complicated and never mind the reluctor wheel. All the kids at the car meet this weekend enthusiastically explained what they were able to accomplish; not what was impossible.
On any swap, where the rubber meets the road lies in the ability to fabricate. If you can fabricate, you can make most things work the right way. What's easy to some is impossible to others, and they will tell you. And that's why some folks confuse the right way with the easy way; that's how my $2300 ACE kit was conceptualized. That's money I could have used to do the swap the right way. Shame on me for believing it was the only way.
Again, my opinion--and I didn't help develop the ACE kit--the transfer case adaptor is the right solution.
--Chris
--Chris
#1519
Chris,
You made the comment:
I did not make that claim. My point above was:
You further discuss “the right way.” In my opinion, “the right way” does not depend specifically on the choice of drivetrain, “the right way” means factory-level integration, or near-factory level integration of the foreign drivetrain, so that all (or nearly all) of the factory stuff operates. I’ve never said the Gen 4 and 6L80 was impossible - I’ve discussed the technical hurdles to that setup, and discussed solutions to overcome them.
Both swaps can be done; however, the amount of work involved and cost can be vastly different. What is best for each person will be dependent on their situation. However, it is simply inaccurate to describe both of these methods as comparable projects. Many people overlook the electrical complexity and underestimate the amount of fabrication. Even if someone has the fabrication ability, fabrication will not solve the electrical issues. This is why I’d describe many of the Gen 4 / 6L80 swaps I’ve seen as “incomplete.”
Having reviewed builds of both types, observed the parts required, the costs of each, and what it takes to make each work to a similar level of functionality, the Gen 3 and the 4HP setup is more straightforward to finish. People should be aware of what they are getting into.
To further elucidate the comments regarding Gen 4:
The tap-shift is a substantial issue if you plan on offroading. Having manual mode that holds the gear for the transmission is an important feature if crossing an obstacle. GM did plan for this, but with their Corvette TCM OS. Since most people are using truck engines/ transmissions as donors which do not provide this functionality, they need custom programming, so that the Corvette OS programmed into the truck TCM can be used to overcome this. You most-likely would need a tuner that knows what they are doing to get this to work correctly. Since the TCM is located inside the 6L80, this often involves removing the 6L80 valve body to remove the TCM to send it out to be tuned with the ECM. If you have someone local that can do this, or can remote into your computer and tune (e.g., with HPTuners) you might be able to get around this last part.
For the shifter, you can use the factory shifter with a dedicated switch for tap shift, or you have to fit a new shifter that supports tap shift. Changing the factory shifter to work with the 6L80’s throw is easier, because a lot of the GM shifters are deep, and the 6L80 transmission is tight up against the top of the transmission tunnel. The neutral safety switch, low range lockout, reverse lights, and gear indications on the dash are other issues that tie into this. There are varying ways to solve these issues, but the way that preserves the most functionality requires dedicated electronics. Similar to what I designed here: https://landroverforums.com/forum/en...nstall-115683/
All the later GM ECMs have the ability to control electric fans via relays without separate controllers. PWM fans that can ramp up/down require separate controllers. With using the 4HP setup you can also run a viscous fan, but this is more difficult with the 4L80 and 6L80 because of the length.
The GM drive-by-wire is a substantial issue if you’re running the 4HP, as they have electrical compatibility issues. Besides fitting the pedal, the other issue is cruise control. It adds significantly more under dash wiring to use the GM cruise control with the factory buttons. For Gen 4, aftermarket cruise control systems or can-bus interfaces are required, which is an additional expense.
St1ck (03-12-2024)
