Discovery 2 LS Conversion
#671
On my birthday I had the wife indulge me
for an hour and we took an lr4 for a test drive. Man that 5.0 was awesome. I will have a 5.0 powered lr4 one day. From what I’ve researched if you keep up on the maintenance and do the timing chain guide upgrade your all set.
I originally wanted to be one of ave’s beta testers but it didn’t happen so I’m doing the rover v8 build for my d2 but if he eventually offers the conversion parts I would be interested in converting the p38. To me that’s a cruiser that could use the power.
#672
#674
#675
The following 2 users liked this post by 05TurboS2K:
Roverbeachbum (12-23-2019),
stereophile33 (12-23-2019)
#676
That would be awesome, but I don't think it would fit.
It's torque would probably grenade the D2 transmission(if it could even be adapted to it), but with the 10spd Ford...yeah, I'de drive that, lol.
I have the 3.5 ecoboost in my '19 F150, and it has 100 more foot pounds of torque than the 5.0 does.
That set up in a D2 would be incredible.
A wrecked late model F150 with the drive train and wiring harness, swapped into a D2(weekend driveway swap, lol), now we're talking.
#677
![Smile](https://landroverforums.com/forum/images/icons/icon7.gif)
Forgive my ignorance. My mechanic skills are not at the level of most on this forum. I was curious if by using an LS motor with a GM trans and adapter to discovery transfer case could one bypass the electronic issues with the discovery ECU and transmission? Using aftermarket dash cluster and just doing away with traction control, hill descent, and ABS, wouldn’t you just have an old school four wheeler or is the disco ECU just too integral to the truck. Learning lots from this forum, apologies if it’s a stupid question. I was thinking that if I could dumb down the complexity of the swap it might be something I could handle. Thoughts?.
#678
#679
On that note.....
Traction control in this vehicle is a pretty sad system all in all. I mean, a cheap locking diff front and rear would be FAR superior off-road than our disco's TC system. As for hill decent..... it's called a brake pedal, LOL. I don't understand hill decent function at all, that is, I don't understand how any engineer could ever have imagined it being needed or worth developing. Today's vehicles have disc brakes! Notice every Jeep seems to do absolutely fine in the most insane off-road situations without "hill decent".
So with that said, yeah probably a very reasonable thing to consider, GM motor, tranny and gauges etc.
Sixpack577 (01-02-2020)
#680
So the big question then is how dependent are the other systems in the disco on the ECU. Guessing ABS will be gone, although Not really sure if it would be a big difference. How about systems like air conditioning,stereo, etc. Aren’t they all tied to the ECU? It almost seems like stripping the truck of it’s modern technology and eliminating all that prevents an LS install rather than trying to work with the disco ECU would make it doable. Then building up from there. I just wonder what else would be lost when ECU comes out.
Again, my experience is limited to much older types of swaps, I don’t speak ECU.😱
