Forum Help & Suggestion Center This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself.
Coolant in oil sump or Leftover degreaser from cleaning it last week??? pictures inc.
Old Feb 26, 2021 | 09:39 PM
Percy's Avatar
Default Coolant in oil sump or Leftover degreaser from cleaning it last week??? pictures inc.
So last week I dropped the sump to replace the gasket. I cleaned the **** out of the oil pan using degreaser. I was extra particular about making sure I got the degreaser all out and dry before I reinstalled the sump. Turns out parts geek sent me an obviously used and stretched gasket that was in worse shape than the one that came off with the sump. So I put the old gasket back on with the sump and dealt with the oil leak to get me to work and back until the actual new one came.(Today) Just dropped the sump and found this, oil and this whatever substance(socket extension pointed at it) seemed to be completely seperated not mixed at all (The oil appeared to be translucent and normal as I was draining it) Im curious could this be a result of not getting all of the degreaser out of all the nooks and crannys of the sump or is someone out there 100 percent this is a small head gasket leak?? Also Ive never dealt with head gasket issues before, Do they tend to just blow out at once with indisputable evidence or does the issue start small and gradually get worse?
zuke
Mar 28, 2016 03:55 PM
OffroadFrance
Off Topic
May 7, 2014 04:03 PM
Q8_Discovery
Oct 24, 2012 05:33 AM
VegasRover04
Mar 9, 2012 09:25 PM
andrew65
Off Topic
Jan 28, 2009 09:50 AM
