Freelander Talk about the Land Rover Freelander within.
2004 freelander LN 2.5L v-6 mech. timing.
Old Dec 1, 2011 | 10:10 AM
mississippimech's Avatar
4th Gear
Default 2004 freelander LN 2.5L v-6 mech. timing.
04 freelander LN 2.5L v-6; timing disturbed (hey I didnt do it I swear!!); crank in "safe" position; cams set and locked correctly; manual says next step is to insert flexplate ( they call it something else, but we all know what it is) locking pin, however, the holes dont align. at this point am supposed to rotate the crank so i CAN install the pin prior to timing belt install?? as it is now, timing CLEARLY not right, when cranking engine, air blows OUT of intake!!! HELP i think the manual makes assumptions that the reader is a factory tech.
Old Dec 1, 2011 | 10:52 AM
jafir's Avatar
There is a freelander section, that might get you better results. Most of us in the Disco forums wouldn't touch a freelander with a ten foot pole. ;-)
good luck!
Old Dec 5, 2011 | 10:56 AM
4th Gear
look, its a 2.5L v-6, it doesn't matter if its in a Sherman tank, its the motor.
Old Dec 6, 2011 | 07:39 AM
Rovin4life's Avatar
actually you should have no interference with the valves when you hand crank it over.
if you start it up with the timing wrong the valves bend and thats goes the motor.
take the spark plugs out, then the air will escape there.
Martin Rodriguez
Feb 25, 2014 08:55 PM
Disco Den
Mar 9, 2010 04:22 PM
jayandy
May 28, 2009 08:47 AM
tads
Aug 23, 2007 07:10 AM
