Freelander Talk about the Land Rover Freelander within.
Bottom radiator hose cold
Old 05-09-2013, 09:10 PM
amytre75's Avatar
3rd Gear
Default Bottom radiator hose cold
My 05 freelander overheats after about 40 minutes of idling. The top return hose that goes from engine to radiator is at running temp but the bottom hose is still cold. Is the radiator clogged or the water pump not working
Old 05-09-2013, 10:30 PM
You can make more diagnosis on the condition of the radiator by checking the temperature of the fins (not frame) from top to bottom in a vertical line, engine warmed up and off. More than 10F cooler at bottom indicates radiator sludged up. Aluminum radiators by Rover are a replace item, like a hose. Water pump would show up faster than 40 minutes.
Old 05-30-2013, 04:59 PM
amytre75's Avatar
3rd Gear
Default radiator
i removed the radiator and water came out both fittings. I can see that it is a replacement already. My question is there a way to visually see if the radiator is stopped up or do i need to take it to a radiator shop to get it professionally done.
Old 05-30-2013, 05:14 PM
The type of radiator with plastic side tanks is usually too costly to repair vs outright replacement. A shop may be able to flush and evaluate it.
Old 05-31-2013, 02:52 PM
Rovin4life's Avatar
Make sure its bled properly but chances are you have an engine issue.
Old 06-15-2013, 01:39 PM
knoxethan's Avatar
Hi I have the some problem with my V6 freelander overheating we changed the water pump, thermostat, expansion tank 5 times, for a month it was okey then it start overheating, toke it to a dealer in Lusaka Zambia he says i need to change the head gasket. they also say some gas is coming through the expansion tank that is why the water is going out? how do you do the test on the gas?
what could be the problem?
Old 06-15-2013, 09:19 PM
They refer to exhaust gas, allowed to seep into the cooling system by the bad head gaskets. This boils the coolant out of the container furiously. There is a chemical test to confirm this, does maybe 15 tests, about $60, changes color with products of combustion are "sniffed" in coolant.
Old 06-16-2013, 02:23 PM
knoxethan's Avatar
thanks
i am in Zambia would you tell how much this some tester would could? and who sell it?
Old 06-16-2013, 02:42 PM
knoxethan's Avatar
if we change the head gasket this problem will go?
Old 08-11-2013, 05:52 PM
mountainrovernc's Avatar
Did you ever find the cause? My 02 has the same issue. Took of the radiator hoses and ran water through the radiator - runs through to bottom in a matter of seconds and drains completely so don't think radiator is the issue. Bottom hose is very cold - no coolant passing at all. Suspect the thermostat but looks like a real bear to replace.
Quick Reply: Bottom radiator hose cold
