TD4 wont start
Just got a 2003 TD4 that wont start on key without starting gas. It doesnt matter if engine is cold och warm, same problem. When i roll the car it starts fine.
The engine is running fine when it starts, no problems when idle or power loss.
All injectors measures the same about 0,6Ohm
No error codes
Fuel pump replaced about a year ago. also tested the fuel regulator at the same time and it was fine.
No error codes
