Freelander Talk about the Land Rover Freelander within.
Trans axel case fluid?
Old Aug 28, 2007 | 10:07 AM
merleti's Avatar
4th Gear
Default Trans axel case fluid?
What type of fluid goes into the trans axel case on the right hand side? I pulled the plug by mistake and noticed the viscosity is not the usual 80w- 90 w that othertransfer casesrun.
Old Aug 28, 2007 | 01:14 PM
Default RE: Trans axel case fluid?
Can't help you with that question but would let you know just in case, the tranny does not take regular ATF, it takes a special fluid take only dealers sell, may be the case for your transaxle also.
Old Aug 28, 2007 | 05:24 PM
merleti's Avatar
4th Gear
Thanks, yes I used the 402 fluid for the transmission. I noticed the debri in the transfer case was much higher than the transmission. I'm thjinking this is due to the breather hole location. It is much lower than the transmission breather and is at an upward 45 degree or so angle. Looks like dirt can just ride right down it. I placed a filter on it and the tranny breather.
GARovee
Aug 22, 2010 09:57 AM
josemex
Jul 22, 2009 11:09 AM
khuds308
Mar 9, 2009 02:42 PM
brianex
Jan 9, 2008 09:08 PM
bklahl
Sep 2, 2007 11:39 AM
