'03 US RANGE ROVER NO CRANK
Hi,
We have an 03 Range Rover that we love. Things were going well until the other morning when it would not start. The remotes unlock the doors, the key turns in the ignition,the dashlights come on,but the engine does not crank. There is a new battery, we performed the key reset procedure we found online, and if you jump the starter solenoid it will crank. While she turned the key I tested and found no signal going to the solenoid. Any ideas where else to look? I dread the thought of another 60 mile tow bill.
Thanks in advance,
Will
Thanks in advance,
Will
Even if the remotes lock and un lock the car if the Key isint ID'd by the engine ECU the car wont start.The keys have a coded chip in them.and the ignition switch has an antenna built into it. A dealer needs to go into a real time monitering mode to see if the nessary ECU's see the key in the ignition. Another Dealer only option.[:@]
cfryor
10-03-2012 07:42 AM
retrac
09-12-2008 03:52 AM
40ranger
03-19-2008 05:11 PM
kraelo
03-19-2008 05:06 PM
