07 l322 4.2L with P0128 Codes and weird revs
Old Nov 23, 2015 | 08:35 PM
me6067's Avatar
Default 07 l322 4.2L with P0128 Codes and weird revs
Hey guys,
I normally post in the discovery2 section but tonight I am helping out a friend who just got a new to himself a new to him 07 l322 supercharged.
Truck drives great but has a P0128 code that comes up. My code reader refers to this code as Coolant Thermostat (coolant temperature below thermostat regulating temperature). Cleared the codes tonight, went for a quick spin and the codes didn't come back. This said the coolant temp reads out between 165 and 178 deg F and the temperature fluctuates quickly depending on being at a red light or driving a long between those two extremities. To me this sounds like possibly the thermostat or fan-clutch or sensor could be the issue. Whats the normal operating temp of these Rovers?
Any help would be appreciated...
Also another weird thing we noticed tonight... When idling and you rev the engine up a little or give it a tap of gas the engine starts to go up and down in rpm's from 500-1200rpm back and forth for a good 10-20 seconds before stabilizing. Any ideas?
Old Dec 13, 2015 | 04:12 PM
LR Techniker's Avatar
More than likely have a thermostat stuck open. I would replace the T-stat and clean the throttle body for the weird rev issue.
Old Jan 3, 2016 | 12:50 AM
RoverDoc88's Avatar
normal temps should be around 195 the thermostate needs to be replaced
J8298c
Sep 21, 2023 02:08 PM
TOM R
Feb 22, 2023 09:40 AM
skogly
Jun 12, 2007 10:35 AM
kaczman
Oct 4, 2006 11:35 AM
Cleggy
Mar 4, 2006 06:34 AM
