1998 range rover 4.0 purge hose
Old Dec 15, 2009 | 02:56 PM
fabbrojo's Avatar
7th Gear
Default 1998 range rover 4.0 purge hose
at some point in time the purge hose on my 4.0 got intentionally plugged. not sure what the impact is and where to connect it to if it is necessary. a photo of a 1998 4.0 showing the purge hose would be very helpful. if u need more info, pm me at fabbrojo@xplornet.com....thnx
Old Dec 15, 2009 | 05:31 PM
wilson96rr's Avatar
I you tell me what the purge hose is, I will be happy to look at mine and tell you where it connects to.
Old Dec 16, 2009 | 01:50 AM
fabbrojo's Avatar
7th Gear
Default picture of purge hose
i am going to try and attach a picture of the purge hose.....
Old Dec 16, 2009 | 07:15 AM
wilson96rr's Avatar
Looks like a coolant hose that goes from the top of the intake manifold to a connector on the bottom side of the throttle body. Probably there to prevent the throttle from freezing up in extreme cold. Hope that helps.
Old Dec 16, 2009 | 07:50 AM
fabbrojo's Avatar
7th Gear
the vacuum is towards the visible side of the purge hose on the diagram. but i will check to see if there is a connector on the underside of the throttle body. if i pull the plug from the purge hose, the idle jumps to apprx. 2000rpm. nothing to connect to under the throttle body. if u can offer a picture of where it connects, perhaps i can figure it out. thnx,,
Old Dec 22, 2009 | 07:38 AM
fabbrojo's Avatar
7th Gear
Unhappy
anyone with a 98 range rover 4.0 out there ? please take a look at your engine and see if u have this hose. in need of help !!!!
D2 2003
Nov 7, 2017 07:41 AM
Sam95disco
Dec 6, 2011 08:52 PM
Brisket
Aug 10, 2011 07:49 PM
rsr50
May 6, 2008 10:55 PM
BuckMontecristo
Jul 27, 2006 10:19 AM
