3.9/4.0 heads
Old Nov 10, 2009 | 06:14 AM
mrevo0's Avatar
4th Gear
Default 3.9/4.0 heads
are the heads interchangable for these engines
what other heads will bolt on to my 3.9 with no hassles
i can get a set with 70,000 on them for 400 is that a good price?
Old Nov 10, 2009 | 10:27 AM
They are not interchangiable, check out this link, http://www.roverlandparts.com/discov...der-heads.aspx
Old Nov 10, 2009 | 06:09 PM
mrevo0's Avatar
4th Gear
Default heads
am i correct in assuming that the 94-95 discovery 3.9 parts will fit on the 89 3.9 range rover
when i am told the vin is "2" this is the engine code correct?
are all the vin"2" parts interchangable
Old Nov 10, 2009 | 10:28 PM
handsome rob's Avatar
Some parts will interchange, what exactly are you trying to swap? I am assuming you are meaning the keads by the post above. You can get your current heads completely rebuilt for $600 just about anywhere, a couple hundred of dollars for like new is better than those 70,000 mile ones.
If you look locally you can find a god deal on the whole engine with decent mileage. There is one locally here that is for $750 with all the accessories with 110K on it. I think a swap is easier then heads anyways in my opinion.
Old Nov 15, 2009 | 06:27 AM
mrevo0's Avatar
4th Gear
Default swaping engine
just bought a 95 discovery 3.9 for 425, so the engine swap is coming now, not the heads, then maybe rebuild the original engine over the winter,
JBEGIN
Jun 27, 2009 12:38 PM
kraelo
Apr 7, 2008 11:38 AM
EVN137
Jun 5, 2007 06:10 PM
dcnellie
May 11, 2007 01:00 PM
rcm
Nov 5, 2006 10:27 AM
