3.9/4.0 heads
They are not interchangiable, check out this link, http://www.roverlandparts.com/discov...der-heads.aspx
am i correct in assuming that the 94-95 discovery 3.9 parts will fit on the 89 3.9 range rover
when i am told the vin is "2" this is the engine code correct?
are all the vin"2" parts interchangable
Some parts will interchange, what exactly are you trying to swap? I am assuming you are meaning the keads by the post above. You can get your current heads completely rebuilt for $600 just about anywhere, a couple hundred of dollars for like new is better than those 70,000 mile ones.
If you look locally you can find a god deal on the whole engine with decent mileage. There is one locally here that is for $750 with all the accessories with 110K on it. I think a swap is easier then heads anyways in my opinion.
JBEGIN
Jun 27, 2009 12:38 PM
