96 rr 4.6 hse
Old Feb 2, 2010 | 12:21 PM
middleman496's Avatar
lol as soon as i can get my rr up my garage i will post up pics up my findings! just gotta find a way to get it up about 20 feet worth of hill form the driveway to garage :P
Old Feb 3, 2010 | 12:44 AM
handsome rob's Avatar
Tow it up with another vehicle or a winch if you have one. I have had to bring other vehicles into the garage using one as an anchor and then a come along for getting it all the way in, it is some work but it needs to be done.
Old Feb 11, 2010 | 06:19 PM
update!
got a buddy of mines to tow it into the garage! it's wrenching time! lol but i work full time and also go to school full time >< well it's progress in the making!
questions:
what kind of oil for the Tranny?
what kind of oil for the differentials?
what kind of oil for the transfer case?
what size is the square bit to take of the oil plugs on the transfer case and differential?
will be posting pics on my progress wish me luck! and thanks in advance to all of you that help me out!
Old Feb 11, 2010 | 06:50 PM
LRScott's Avatar
Transmission and transfer case fluid is Dexron III ATF. 80-90W Synthetic gear oil works great for the differentials. I haven't opened up the transfer case drain or fill plugs, but I know just the end of a 1/2inch socket wrench with nothing attacked to it works fine for getting the differential fill/drain plugs out.
Old Feb 11, 2010 | 07:27 PM
awesome! gonna go put a little wrench time in guys, will get back to you when i'm done for the day
Old Feb 12, 2010 | 03:30 PM
i'm in the process of sliding out the rear axles to take the diff out and check it. what's the best way to take off the axles i.e first the brake lines then the sensor. thanks!
Old Feb 12, 2010 | 03:59 PM
okay well i got the right axle out. i loosened the brake line screw to the caliper, loosened the brake line bracket on the hub, took out the sensor, then took the rest of the hub screws off. hub and axle just slid right out no problem
Old Feb 12, 2010 | 05:29 PM
should the diff just pull right out after i take the two axles out? lol i'm having the hardest time pulling that thing out. alright shoots
Old Feb 13, 2010 | 01:03 PM
Old Feb 13, 2010 | 01:08 PM
so that's my current progress right now the axles splines are still good, need to rebuild my calipers get new rotors and pads even though they have a lot of meat on them but are scored. my delima right now is the diff. will not i repeat will not come out of the housing ><. any suggestions? any suggestions to take out a stuck filler drain screw?
was loading my trunk with goodies before my diff broke here's a pic
