98 RR SE Wont Start
Old May 19, 2007 | 12:22 AM
RCHILDRESS's Avatar
7th Gear
Default 98 RR SE Wont Start
[hr]
I am having issues with my 98SE RR. I drove it into town today and did some shopping for the house but when I got ready to leave 2 hours later it wouldnt start. I left the windows cracked assuming I would only be out of it for a few, but you know ho wthat goes. Well now it wont turn over I have a felling that it has something to do with the alarm I did see someone leaning on it while holding a conversation with someone in a near by parking spot. I was going to replace the starter, but I took a jumper cable and ran it to the smaller starter cable and it turned but didnt start even while a friend turned the key to the start position (3). Well I also tried disconnecting the battery for 30 minues but that did nothing except loose my programmed stations in the radio (glad I remembered that code). If any one has some advice I would greatly appreciate it. Thanks
rc
rqchildress@bellsouth.net[/align]
Old May 19, 2007 | 07:25 AM
Default RE: 98 RR SE Wont Start
You never disconnect your battery to try and fix something, your ECU will loosew it's memory also as well as your remotes getting screwed up.
Look in your owners manual and follow the procedure for reprograming your remote first. Then try and start it, if it still won't turn over try jump starting to the battery.
Mike
Old May 19, 2007 | 01:50 PM
RCHILDRESS's Avatar
7th Gear
OK thanks for your advice, "jump starting to the battery" is that just like if your battery went dead, or should I do something different?
Old May 20, 2007 | 08:53 AM
I believe there is a process that you must do to get your remote to talk to your ECU, and thank God Rover only used this on a few Rangies like yours.
Mike
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
