99 range rover HSE have problems starting
Old Nov 6, 2011 | 03:34 PM
streamway0's Avatar
5th Gear
Default 99 range rover HSE have problems starting
I have been having problems starting my 99 range it just started doing this out of the blue a month ago. It cranks and i have to crank it like 5 to 12 times for it to turn over and start. Once it starts i can turn it off and on like regular the rest of the day, but sometimes i now find myself running low on power trying to crank it so many times. I bought a new battery, installed new spark plugs, new oil filter,new fuel filter, and i just ordered a crankshaft position sensor/inter-motor crankshaft sensor someone told me it could also be a bad Camshaft Position Sensor what do you guys think could be the problem?
I haven't installed the fuel filter or crankshaft position sensor/inter motor crankshaft sensor yet
Old Nov 7, 2011 | 07:40 PM
Rovin4life's Avatar
crankshaft position sensor is your likely cause with no codes. especially intermittent.
make sure you order the correct one by the vin, 99 is a half year between two different motors and engine management systems so the parts don't match up at all.
Old Nov 8, 2011 | 03:10 AM
streamway0's Avatar
5th Gear
error code is p1884 i picked up one from advanced auto parts here it is Buy BWD/Intermotor Crankshaft Sensor CSS1050 at Advance Auto Parts
Old Nov 8, 2011 | 03:29 AM
LRScott's Avatar
P1884 (37)
CAN message: Engine air intake temperature invalid
No apparent effect.
There is a temp sensor before MAF. That could be going out, idk... Check to see if it is connected properly. BTW, is your rover a bosch or gems rover? This will really help us out in future diagnoses. You might consider adding it to your signature.
This will help you determine what engine you have. http://www.roverparts.com/TechTips/boschvsgems.cfm
Old Nov 8, 2011 | 09:10 PM
streamway0's Avatar
5th Gear
i HAVE hse 4.6
BOSCH Engine
Old Nov 9, 2011 | 07:00 PM
streamway0's Avatar
5th Gear
crankshaft position sensor/inter-motor crankshaft sensor installed fixed problem but have a abs fault showing up in dash
Old Nov 10, 2011 | 03:57 AM
LRScott's Avatar
does it go away after you drive above 1mph initially? If yes, that is normal.
Old Nov 10, 2011 | 10:56 PM
streamway0's Avatar
5th Gear
I have three more codes p1171 p1174 and p0455
Old Nov 11, 2011 | 05:01 AM
455 is evap system purge, others are lean condition bank 1 and 2; could have knocked a vac line off during your work.
Jordanmd88
Jun 2, 2010 07:49 PM
PeeweesTires
Feb 24, 2010 06:50 AM
Canderson76
Nov 19, 2007 02:27 AM
Stickestar
Appearance & Camping Set Ups
Dec 13, 2006 03:25 AM
finetrophywife
Aug 5, 2005 03:40 PM
