ABS pump
Old Aug 3, 2006 | 04:47 AM
Boarder209's Avatar
5th Gear
Default ABS pump
I own a 91 range rover and recently my abs pump is making a very loud noise. I have lost all abs power brakes and am now using my manual brakes. My ABS light stays on all of the time even when I disconnect the power to the ABS pump. I think that the problem is the ABS pump but is there anything I can check before I go and buy an expensive new one? I appreciate anyones suggestions.
Old Aug 3, 2006 | 01:04 PM
Default RE: ABS pump
Take it to a shop and ask the to at least confirm what your beliefs are.
Mike
Old Sep 22, 2006 | 04:53 PM
beats's Avatar
I'm having a similar problem with my '90 classic. I've worked out that the noise appears to be air in the pump which can be seen when the pump is bled and the noise stops. I'm going to replace the hose between the reservoir and the pump as I suspect this may be allowing air into the system. This is the second pump and accumulator I've had fitted so i'm fairly sure its not either of these units at fault. I'll let you know how I get on.
Old Jan 3, 2007 | 01:57 PM
LayerCake's Avatar
3rd Gear
beats - where did you get the hose?
I am having a similar problem. The car has been sitting for a few months, fired her up and the ABS pump has been whining w/no brake pressure. I thinking a line cracked somewhere and is allowing air in, but I haven't had the time to check it out yet.
Does anyone know of a way to bypass the ABS altogether?
Old Jan 3, 2007 | 03:00 PM
Don't just start replacing part before a diagnoises is done, could be something as symple as an accumulator failing. There are plenty of places to buy good guaranteed used parts also.
Mike
Old Jan 3, 2007 | 03:22 PM
LayerCake's Avatar
3rd Gear
Mike - can you list a few. I also need a new alternator.
I was going to start w/bleeding the system and seeing what happens, hopefully it will be something simple and not the ABS pump itself.
Jason
Old Jan 3, 2007 | 03:39 PM
Take a look at ,http://www.roverlandparts.com/
this is a good place to start.
Mike
dammad
Jan 26, 2009 01:50 PM
barranr
Jun 3, 2007 06:36 AM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
