airbag fault
RE: airbag fault
Since the op is being vague and I have the same problem, I will leave my info. 99 RR HSE92K miles.Never any problems and all of a sudden one day I left it running to warm it up and came out to the truck and found the srs light on. Drove it for a few days and then it went out. Every few weeks it comes back and then turns off after a certain amount of starts. It must be something intermittant. Thought it would be a clockspring but since it happenes when I am not turning I am doubting that. Any infor for me and/or the op?
on
RE: airbag fault
Normally when the SRS light is on it is either because of a low voltage fault or you have one of your SRS parts starting to fail as well as a bad seat belt tensioner.
When the light is on, you should go by the shop you use and have them scan the system and find the problem.
By the way, the one thing that is unusual with your truck is that normally if the light comes on, it won't go off.
kbarker27
10-13-2023 04:03 PM
06Range
05-08-2013 09:01 PM
