airbag fault
Old Nov 18, 2007 | 03:23 AM
wease206's Avatar
Default airbag fault
need help airbag light on
Old Nov 18, 2007 | 07:30 AM
Default RE: airbag fault
On what year and model, how many miles on the vehicle and what is your suspension doing when the light is on?????????
Old Dec 21, 2007 | 11:34 AM
wease206's Avatar
mySRS light
Old Dec 21, 2007 | 12:59 PM
If you want help, you will need to ask us a specific question and also give us the year, model and mileage of your truck?
Old Dec 21, 2007 | 02:52 PM
Rfactor's Avatar
Since the op is being vague and I have the same problem, I will leave my info. 99 RR HSE92K miles.Never any problems and all of a sudden one day I left it running to warm it up and came out to the truck and found the srs light on. Drove it for a few days and then it went out. Every few weeks it comes back and then turns off after a certain amount of starts. It must be something intermittant. Thought it would be a clockspring but since it happenes when I am not turning I am doubting that. Any infor for me and/or the op?
Old Dec 22, 2007 | 11:23 AM
Normally when the SRS light is on it is either because of a low voltage fault or you have one of your SRS parts starting to fail as well as a bad seat belt tensioner.
When the light is on, you should go by the shop you use and have them scan the system and find the problem.
By the way, the one thing that is unusual with your truck is that normally if the light comes on, it won't go off.
Old Dec 22, 2007 | 06:23 PM
bavarian_range89's Avatar
Mine is on at all times and it's an '02 with 102k miles...
Old Dec 26, 2007 | 03:24 AM
wease206's Avatar
98 RR 102k miles been on for 3mth now
06Range
May 8, 2013 09:01 PM
faheemf1
21
Feb 29, 2012 08:41 PM
val
Dec 18, 2008 09:26 PM
mom2bekah
Apr 13, 2008 02:09 PM
