Battery drain and can not start
Old Jul 28, 2007 | 04:04 PM
kingkitesurf's Avatar
3rd Gear
Default Battery drain and can not start
Hello as a newbie I have been lurking here and on other forums for a while now, this is a great forum...!. My 96 RR 4,6 has a problem and I hope you can help.
My battery keeps draining but very unpredictive. There are many posts but I have tried the following. I have a new 108 amp battery, the R/F receiver has been replaced, all grounds appear good since all electrics work well when driving. There is a 13,8v current on the battery from the alternator when running. When shutting down you see (with a volt meter) the battery drain... on other moments it sticks where it is (12.20) for the whole testingday. But then 1 hour later it can bedrained. The alarm seems to not be working (at least no horn).
At this moment I cannot even start with starterboosters since the keys are not in pair. Somehow I need to enter a code... I tried the key turning trick as described in the manual... doesn't work.
Does anybody have suggestions on the drain cause and how to reinstate the key so I can start again? Thanks.
Regards Job from Amsterdam
Old Jul 28, 2007 | 06:08 PM
Default RE: Battery drain and can not start
It is spelled out in your owner manual how to reset everything after the battery goes dead.
Mike
Old Jul 28, 2007 | 11:54 PM
3rd Gear
I am downloading
zski128
Mar 2, 2013 06:28 PM
oilspotLR
Aug 21, 2012 09:55 AM
Evan5291
Jul 26, 2011 06:06 AM
shawnjones
Apr 24, 2008 03:15 PM
Dopey
Jul 22, 2007 07:09 PM
