Before I sign on the dotted line
Old Jul 15, 2012 | 06:15 PM
Hbodo08's Avatar
Exclamation Before I sign on the dotted line
Hey everyone im not new to forums but im new to the Land Rover scene, im in the process of looking at a 2006 RRS Hse it has 74,000 miles on it but the over all condition is excellent!
But i have a few questions for you guys.. Thats why i joined this forum to find out some answers!
Common problems with this year and make?
Things i should look out for?
Websites for parts?
Just general knowledge on the vehicle itself?
all your comments im sure will help me.
Old Jul 15, 2012 | 06:26 PM
a pre purchase inspection by a mechanic is always cheap insurance
Atlantic British, Rovers North, BP Utah, British Pacific, and there are more.
Rovers in general do not like overheating, but dash gauges leave a lot to be desired. Check out the Ultra Gauge UltraGauge Automotive Information Center and OBDII Scan Tool which can display stuff, alarm points for same, plus read and reset codes. $70.
Old Jul 15, 2012 | 07:01 PM
hilltoppersx's Avatar
the air suspension should be checked for leaks. also check for coolant leaks, pull the shield off and check around radiator/hose on main radiator and also the s/c cooler up to the expansion tank, check the tank level. look for puddles underneath the vehicle. if there is a puddle check the color of fluid. if its clear it could be water from a clogged A/C drain, orange is coolant, red is transmission, brown or black is oil/gear oil
Old Jul 15, 2012 | 09:18 PM
Hbodo08's Avatar
thanks thats the info i needed right there
Old Jul 16, 2012 | 05:43 PM
LR Techniker's Avatar
I'm pretty sure its not a matter of "if", but more like "when" the air suspension will start to leak. You may want to consider an extended warranty and MAKE SURE items like the air shocks are covered.
Most of the times I see a shock come in thats leaking, the compressor will run itself to death and compressor replacement alone can run you $800+ (from the dealer).
Old Jul 16, 2012 | 07:48 PM
there is another tip. dont buy a land rover or range rover if you wont work on it yourself unless of course you have bottomless pockets.
griff black
Jun 23, 2016 05:59 PM
griff black
May 1, 2010 07:33 AM
RROJ
Apr 24, 2010 09:49 AM
howardw
Aug 3, 2009 10:37 AM
pilsner
Jan 2, 2009 12:51 AM
