cannot stop leak in the high pressure line
Old Feb 25, 2009 | 09:56 PM
val's Avatar
val
Question cannot stop leak in the high pressure line
I found a leak in my body valve, all of the lines were leaking a little bit.I was proud of my myself, i changed all of the rings, but the high pressure line cannot stop leaking. The high pressure line was not good so i cut worn part and now i cant stop the leak. So i fill all of my bags and disconnected the compressor so i can drive until i can fix it. Any idea of what i did wrong.
Old Feb 25, 2009 | 10:27 PM
ldivine's Avatar
Try using some white lithium grease... it's hard to get a good seal and the grease tends to help.
Regards
Old Feb 25, 2009 | 10:31 PM
val's Avatar
val
thanks ill try tommorow
Old Feb 25, 2009 | 10:33 PM
skyguy's Avatar
Val, did you watch the video on this link yet? It might help you to determine what has gone wrong with you replacement of the O Rings http://www.rswsolutions.com/media.htm
COBRA
May 27, 2013 02:17 PM
CapeRover
May 3, 2013 04:35 PM
JerrodSteph
Jun 12, 2011 06:04 PM
Charlie L
Apr 12, 2005 05:49 PM
