Check engine light
Hard to tell without the stored code that goes with that. You can go by a shop ($89 to read codes), find an auto parts store that will read for free, buy a code reader/scanner for a modest figure, or an Ultra Gauge that will do all sorts of displays and read and reset codes. If lid is not secure, or if you dislodge the air hose that goes to the engine or another vacuum hose or a plug on something, lots of things could make that code.
Thank You
George P
P0174: system to lean bank 2
P0171: system to lean bank 1
Car running fine. I cleared the codes, will see if they recur.
Should I do something else?
Thanks. I also cleaned the MAF sensor. I'll see what happens.
Bill
Well, turns out the check engine light codes meant the ECU had to be reprogrammed. I still don't know why. Would just changing the air filter have something to do with it? I'd like to get a better explanation from the dealer.
