Check engine light
Old Feb 8, 2012 | 09:26 PM
ChefGabe's Avatar
Bill
I had simar issues with my Disco II. I found a leak between the hose and the MAF sensor. And one at the seal by the air cleaner. I taped them up with duct tape (black to match!) cleaned the MAF and cleared the codes. Two weeks and no return. We are embarking on a 1400 mile road trip tomorrow, wish us luck! Hope this helps.
Cheers
Gabe
Old Feb 9, 2012 | 06:18 PM
Rovin4life's Avatar
Rookies and their damn bulletins. They forget that the reprogram was for earlier ones and yet they still didn't diagnose the other stuff. trust me its coming back on sooner rather then later.
Old Feb 9, 2012 | 09:29 PM
drbill2010's Avatar
Originally Posted by ChefGabe
Bill
Cheers
Gabe
Good luck! We'll see if the codes pop up again on mine. So far, so good.
Old Feb 14, 2012 | 02:36 PM
pizzaboy's Avatar
Default check engine light
I have an 06 RR HSE with the same code problem. It comes and goes only during the winter months. I live in CT, from what I am told the gas changes during the cold months and it must be cause of that reason......
Old Feb 14, 2012 | 03:03 PM
Rovin4life's Avatar
i bet its leaking intake gaskets but you need diag
Old Feb 15, 2012 | 12:43 PM
drbill2010's Avatar
Well, so far, all is good. No more codes. The dealer acted like no big deal and just reset the ECU.
Old Feb 17, 2012 | 11:52 PM
RoverMasterTech's Avatar
PFFFFFF... noob dealer tech. (was prob. a plumber or roofer last year) PCV valve. (looks like a flying saucer) only thing that causes lean codes on a rr/w jag motor, the tune update was for the supercharged 2006.
Old Feb 18, 2012 | 01:43 PM
Rovin4life's Avatar
nothing like having the same pcv valve go causing a smoke screen on the road.
of course if you don't pull over the oil level goes from bad to worse.
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
