driver door open from the ouside but not inside? help!
Old Jan 8, 2010 | 02:52 PM
leddifer's Avatar
Default driver door open from the ouside but not inside? help!
my door open from the out side but not the inside. how should i fix this? its a 1999 p38 range rover
Old Jan 8, 2010 | 06:02 PM
wilson96rr's Avatar
Pull the door panel and see what isn't moving when you move the lever. I had the exact opposite problem on mine. Opened from inside but not outside. It was a pretty simple fix.
Old Jan 9, 2010 | 06:44 AM
Rovin4life's Avatar
probably needs a cable.
not a bad idea to do a latch at the same time just in case it doesn't break later on and leave you superlocked out.
joshp01
Dec 5, 2021 07:50 PM
errol
Aug 6, 2013 12:57 AM
Prowler9876
Feb 22, 2010 08:31 AM
roverohio
Jun 11, 2009 06:22 PM
