Help! Our 1999 RR battery died, now engine disabled!
Old Apr 11, 2010 | 06:37 PM
ddemars's Avatar
Default Help! Our 1999 RR battery died, now engine disabled!
Help! Our 16-year-old son left on the headlights of our 1999 Range Rover 4.6 HSE (we purchased it used from a private party one year ago). The battery went dead. The remote would not open the doors. The ignition key would not open the door, either.We had to call a locksmith to get us in. We replaced the battery; message board still said "engine disabled". We let it sit overnight without a battery; we just put it back in and got the same message. We tried all of the tricks we read about online (i.e. key in ignition, key out of ignition, pressing "unlock" on the remote, closing the bonnet/hood, etc.). Nothing worked. We cannot use the EKA method because the ignition key will not work in the door. Is there any way to get this rig running without towing it to a Landrover dealership? Are they the only ones with the t4 diagnostics to get it running and resynchronized again? At least we know no one can steal our car while it sits there unlocked! Thanks in advance for any advice!
Old Apr 11, 2010 | 06:49 PM
LRScott's Avatar
sorry, but you need the EKA access code to get it up and running. One other thing you could try is put the key in the RR and then disconnect the battery for a few hours. Re-connect it and sometimes the system will see the key in the ignition and re-enable the system.
Old Apr 14, 2010 | 05:45 AM
Rovin4life's Avatar
take off the door panel and dissconnect the lock from the latch and push it up and down like its locked and that should disconnect it.
and why didn't you get a new door lock if you knew it wouldn't work?
4thefamily
Feb 19, 2025 11:09 AM
Lgolf81
LR2
53
Sep 7, 2023 01:56 PM
mgabriel
Dec 23, 2013 11:33 PM
stusanderson
Aug 5, 2012 04:33 PM
