Help please with door lock!!
Old Jun 19, 2008 | 09:44 PM
elementdo's Avatar
8th Gear
Default Help please with door lock!!
Hey guys,
Im new here and this is my first post. Truth is this is my girlfriends car. She is having a problem with her door lock. Weve changed the battery in her remote and everything. It wont lock at all. Nothing will lock with the remote. If we use the button inside it all locks up. But it unlocks when she gets out and it wont re-lock. The whole remote isnt working at all. About 2 months ago we had her rear quarter panel fixed because she backed into my work truck every since then it hasnt worked since we got it back from the shop and they said they did nothing to it and it would be extra for them to look at it. Where should I start looking to find the problem? Where is the receiver module for the remote? Please help ASAP. I leave in the morning for Ocean City. Thanks guys,
Drew
Old Jun 19, 2008 | 09:47 PM
elementdo's Avatar
8th Gear
Default RE: Help please with door lock!!
Sorry guys the car is a Range Rover HSE 04.
Old Jun 19, 2008 | 10:07 PM
roverguy7's Avatar
get in the car, shut the doors, put the key in and turn it on then off quickly(on, not started) take the key out, hold down lock, and press unlock 3 times and then release lock... the led will flash and the locks should cycle, if they dont try ita few times, if it doesnt work you need it checked out... the receiver is behind the upper trim of the upper tailgate
Old Jun 22, 2008 | 05:45 PM
elementdo's Avatar
8th Gear
Thank you so much for your help. The remote works now!! THANK YOU SOOOO MUCH. One more thing though. The door unlocks on the drivers side still. The alarm goes off now but still its not really locking. Any ideas?
Old Jun 23, 2008 | 09:19 PM
roverguy7's Avatar
not really locking as in you can open it with the lock button down? try it with someone else... have them manually push the button down and see if you can open it from the outside. then lock it with the door closed, and see if you can open it from the inside, then try the same thing, but hit lock twice within 3 seconds
junebug
Dec 5, 2020 04:58 PM
Paul Aspen
Nov 4, 2013 02:10 PM
Jason428sc
Oct 17, 2012 07:27 PM
kpl1228
Aug 19, 2012 05:33 PM
DiscoBenjamin
Aug 3, 2011 06:02 PM
