Low coolant warning and mis fire cylinder warning
Old Apr 22, 2018 | 01:30 PM
Robuski35's Avatar
Default Low coolant warning and mis fire cylinder warning
hi guys
I have a 2012 RRS 5.0l sc five months in Arizona
firstly it was low coolant alarm I got Garage to change coolant pipes they said where leaking ..low level still coming up every few days .... I let some pressure off coolant resivor and level comes up then I got mis fire cylinder alarm 2 and 6
First garage said it’s not a head gasket problem and wants $8000 to repair
brought for a second opinion that garage said it’s a faulty coolant bottle and spark plugs cost $1000 dollars but could be injectors which will be be dearer
can anyone one recommend a good reasonable priced mechanic in Arizona
Old May 4, 2018 | 08:36 AM
memphis_rover's Avatar
So if its not a head gasket did they specify what the 8k was for? Perhaps a boat payment? In all seriousness though if these were not shops that deal with rovers regularly I would leave them in the dust. I know the LR3 had coolant level switches that went bad not sure on later models though. Start by googling independent rover shops near you and see what that brings up. If there isn't one close bite the bullet and head to the dealer at least to figure out whats going on with it.
Old Dec 19, 2018 | 02:46 PM
austinlandroverbill's Avatar
OK, now I am really confused.
Are you running the ABS pump in order to avoid having a vacuum bleeder or a son to pump the pedal?
Can I just bleed it the "old fashioned" way: get someone to pump the pedal while I open the bleeder screw.
Been doing it this way for 25+ years on at least a dozen cars with ABS. Is the Wabco/D2 system somehow different?
Old Dec 19, 2018 | 09:44 PM
Think you posted in the wrong thread.
Old Dec 20, 2018 | 08:25 AM
you are correct. Sorry about that.
Amberslaws
LR4
Oct 1, 2019 11:48 AM
attworth
Nov 15, 2018 03:44 PM
pigsonthewing
Feb 3, 2018 06:01 PM
Scrappyq99
LR2
Nov 25, 2016 02:05 AM
satcal0
May 3, 2009 01:54 PM
