no brakes, ac unit and eas...HELP
Old Jun 29, 2009 | 09:17 PM
Donijr's Avatar
8th Gear
well the problem is gone when i change the relay with the key pictured on it, it would be relay 14 but my air suspension wont come up
Old Jun 29, 2009 | 09:54 PM
ldivine's Avatar
Are you simply switching the relays or are you replacing them with new ones?
Old Jun 30, 2009 | 12:09 PM
rr95's Avatar
Originally Posted by ldivine
Engine off the voltage should be around 12v and on it should be around 13.7. I would still check the alternator as 14.7 is high.
GEMS have a plenum chamber with Land Rover and 4.0 or 4.6 on the cover. Bosch engines do not.
I'm not sure you are correct on that voltage Idivine, batteries are misquoted as being 12 volt, they are actually closer to 13. Alternator will push the reading to approx 14.5. Factor in that voltage meters are not generally particularly accurate and I think his readings are just fine.
Old Jun 30, 2009 | 07:54 PM
ldivine's Avatar
I disagree... yes it's probably not going to be 12v but vehicle off it should be no higher then the mid 12s. You MIGHT see close to 13 on a pristine battery. And engine on the battery should not be 14.5. Alternator voltage, yes, but not at the battery.
FightOnUSC79
Nov 26, 2010 09:43 AM
lewis051184
Apr 2, 2009 08:18 PM
simjack
Oct 12, 2008 10:24 AM
1eyescooter
Feb 1, 2007 11:12 AM
daveo
Sep 23, 2006 06:37 AM
