no brakes, ac unit and eas...HELP
I'm not sure you are correct on that voltage Idivine, batteries are misquoted as being 12 volt, they are actually closer to 13. Alternator will push the reading to approx 14.5. Factor in that voltage meters are not generally particularly accurate and I think his readings are just fine.
I disagree... yes it's probably not going to be 12v but vehicle off it should be no higher then the mid 12s. You MIGHT see close to 13 on a pristine battery. And engine on the battery should not be 14.5. Alternator voltage, yes, but not at the battery.
lewis051184
Apr 2, 2009 08:18 PM
simjack
Oct 12, 2008 10:24 AM
daveo
Sep 23, 2006 06:37 AM
