Oil Drain plug.
Oil Drain plug.
Purchase a 2000 4.6 RR last month and have learned a lot here. New question I change the oil this weekend and while doing so I noticed few drops of oil dripping from oil pan plug. May have come from above. Anyhow the plug has a metal washer but no plastic washer. Is that correct or does it need a plastic washer as well? Washer appears to be somewhat cone shaped so maybe that is the seal. Any ideas? thanks
LAND ROVER OIL DRAIN PLUG & WASHER SET DISCOVERY 2 II RANGE P38 FREELANDER LSF100040L ALU1403L OEM | Miami British Corp.
That's the plug and washer, nothing more. You should replace the washer with every oil change. Once they "crush" a few times that's when the leaks can start.
spiderss (01-19-2015)
real_tea
02-15-2013 10:00 AM
1ozeme
05-17-2010 03:11 PM
chiasurf
12-29-2008 11:25 AM
