engine oil drain plug 2006 rr hse
Old May 15, 2010 | 02:38 PM
1ozeme's Avatar
Default engine oil drain plug 2006 rr hse
I can not find a replacement engine oil drain plug/seal local. Need to change oil, will it be ok to reuse the one I now have for one more time until I can order more ?
Thanks.
Old May 15, 2010 | 02:46 PM
Rovin4life's Avatar
we change the entire plug. Its a jag block so a jag dealer can help you out. Or try a ford dealer and show it to them.
Old May 15, 2010 | 03:18 PM
1ozeme's Avatar
Default engine oil drain plug 2006 RR HSE
Thanks Rovin4Life. We live at lease 250 miles from a Jag/RR dealer and the one Ford place and the several parts stores don't have a replacement plug. I am trying to get an opinion
if it will be ok to reuse the 6 mt old current plug one more time until I can order more RR Parts.
Old May 15, 2010 | 03:21 PM
Rovin4life's Avatar
just wait order the part online and dont overtighten the other one. Do that and you are royally screwed. I mean royally screwed.
Old May 16, 2010 | 11:44 AM
LRScott's Avatar
Rovin4life, why is it not ok to reuse the plug? I reuse my plugs all the time. Is there some different design that they use on the Jag engine now that requires you to replace it each time?
Old May 16, 2010 | 11:53 AM
Rovin4life's Avatar
Because the oring is with the plug, eventually it will fail and start to leak. With your vehicle you just replaced the copper oring.
Old May 17, 2010 | 03:11 PM
1ozeme's Avatar
I will wait for new ordered Drain Plug to do oil change. Thank you all so much.
themdg
Jan 25, 2015 01:52 AM
real_tea
Feb 15, 2013 10:00 AM
Rover_Hokie
Jan 15, 2013 01:10 AM
willrok13
Jul 5, 2010 03:54 PM
chiasurf
Dec 29, 2008 11:25 AM
