Oxygen Sensor
Old Aug 2, 2010 | 03:30 PM
gsd2004's Avatar
Default Oxygen Sensor
Hello all,
My service engine soon light came on and I took a trip to Auto Zone. The gentlemen told me that the oxygen sensor is the reason the light came on. Apparently the code reader said Bank 1 Sensor 2. Auto Zone did not carry the part needed and when I go on Atlantic British I see two different items I can buy Oxygen Sensor Front, and Oxygen Sensor Rear. Which is the correct one, and should I look at replacing both? My knowledge about car repair is basic at best however the gentlemen at auto zone said it was very easy and offered to install it for me free of charge. So a little advice from everyone here would be greatly appreciated! How many oxygen sensors are there and at 55,000 miles should I look at replacing all of them??? This is a 2002 P38 Range Rover....
Thank you all in advance!
Old Aug 3, 2010 | 08:53 PM
LRScott's Avatar
I believe there are 4 oxygen sensors. It is usually wise to replace all of them. However, if you are cheap like me you can just replace the one. I would refer to the service manual for more information on which one it is exactly. You can download the service manual at greenoval.com
Old Aug 5, 2010 | 12:12 AM
Rovin4life's Avatar
bank one driver side of engine left hand drive markets.
sensor two is downstream oxygen sensor after the catalytic converter.
Old Aug 5, 2010 | 11:57 PM
handsome rob's Avatar
Was that the only code? I have had a misfire code as well that will say the O2 sensor is having an issue as well. If it was having a misfire as well I bet the sensor is fine.
With 55K the miles are low but the age is there.
xb70valkarye
Oct 21, 2009 05:26 PM
raidernine
Sep 3, 2007 08:22 AM
bonedoc
May 1, 2007 06:49 PM
EATMAN
Nov 10, 2006 12:15 AM
xb70valkarye
Feb 8, 2006 01:52 PM
