Please help Stuck in park!
Check your owners manual or service manual for the fuse's description. Is it a fuse in the engine compartment box or under the seat? Sounds like you have a short somewhere... Do you hear a click when you first push the brake pedal? I think your gear selector lock is shorting out, causing the selector to be stuck and blowing fuses. I doubt the brake switch is malfunctioning, because your brake lights work, but its another thing to check.
You could bypass the fuse with a paper clip, AT YOUR OWN RISK!
Roywilliams14
05-17-2014 01:27 PM
surfrider
09-17-2012 07:10 AM
RobK
05-24-2011 08:41 PM
