Please help Stuck in park!
I have a 98 RR and it is stuck in park. Fuse 13 blows as soon as it touches the contacts. the brake lights DO work but the sunroof stopped at the same time???? What is fuse 13 for? Any help would be great. thanks
Check your owners manual or service manual for the fuse's description. Is it a fuse in the engine compartment box or under the seat? Sounds like you have a short somewhere... Do you hear a click when you first push the brake pedal? I think your gear selector lock is shorting out, causing the selector to be stuck and blowing fuses. I doubt the brake switch is malfunctioning, because your brake lights work, but its another thing to check.
You could bypass the fuse with a paper clip, AT YOUR OWN RISK!
Roywilliams14
May 17, 2014 01:27 PM
surfrider
Sep 17, 2012 07:10 AM
RobK
May 24, 2011 08:41 PM
