View Poll Results: A poll
range rover
100.00%
Voters: 1. You may not vote on this poll
range rover wobbling @ high speed
Old Aug 9, 2007 | 09:07 PM
thawk78's Avatar
5th Gear
Default range rover wobbling @ high speed
Hi need help, I have a 99 range rover 4.6, w/air suspension,while driving at normal speed on the HIGHWAY and I hit a bump on the road, it starts to wobbling, and vibrate, I press the brake to control the steering. I have replaced the damper, and wheel alignment. all steering parts checked ok no play. should I replace the shcoks??? the bags where replace about a yr ago. Please help, its getting a bit $$.
Old Aug 10, 2007 | 01:04 PM
Default RE: range rover wobbling @ high speed
Looks are not the all important inspection, torques all joints, check for looseness in the steering box. I would look towards the tie rod ends.
Old Aug 23, 2007 | 03:53 AM
Bleacho's Avatar
Disco Mike is right...
I had a similar problem with my RR, all attached parts checked out fine, lookedfor advice from this forum,
re-torqued everything back to spec & now she no longer scares me!!! - I even had a couple ofslack wheel nuts!!!
So torque up everything!!
ussattelite
Off Topic
Jul 4, 2017 03:59 AM
kgrab
Nov 12, 2010 04:48 PM
meltdowndave
Oct 22, 2009 06:14 AM
smartkiduwey
Nov 13, 2007 06:50 AM
soupdogg
Sep 25, 2007 12:49 PM
