Rear Axle 99 4.6HSE unknown component
Old Aug 11, 2007 | 07:27 AM
dalfier's Avatar
Default Rear Axle 99 4.6HSE unknown component
There is a cable? leading to the rear axle about halfway between thedifferential and the right rear tire. It enters at the top of the axle. It appears mine has come in contact with the exhaust system and is melted. What is it and its function? Do I need to worry about it?
Doug
99 4.6 HSE
103000 miles
Old Aug 11, 2007 | 07:08 PM
Default RE: Rear Axle 99 4.6HSE unknown component
Is it a cable or the diff vent tube?
Old Aug 12, 2007 | 08:06 AM
dalfier's Avatar
After further investigation, I discovered it was in fact a vent tube. I cut off the melted ends and reattached them together with a rubber hose. Is that ok?
Doug
Old Aug 12, 2007 | 09:29 AM
As long as the end is high up out of the way of any water and the repaired section doesn't leak, you should be fine.
cationmoted
Oct 19, 2012 07:39 AM
cold_surfer
Nov 8, 2008 10:53 AM
dalfier
Aug 30, 2007 02:20 PM
dp_roberson
Apr 29, 2005 12:24 AM
