Resetting washer fluid low fault?
Old Jan 12, 2010 | 06:25 PM
thechidz's Avatar
Default Resetting washer fluid low fault?
has anyone been successful resetting their washer screen low fault? I put in a new battery and had to reset the windows. I also have the washer fluid low fault and the manual says to top up only with the starter switch turned off. does that mean with the key in the ignition and not turned or without the key in. I tried both ways and havent been successful. thanks
Old Jan 12, 2010 | 09:00 PM
wilson96rr's Avatar
I have the same problem with mine. Aparently the sensor is a common weak point. The sensor is cheap but according to the directions I read it is a PITA to change.
ggushee
Nov 28, 2023 01:28 AM
06Range
May 8, 2013 09:01 PM
UkCats10
Jul 12, 2012 12:00 PM
krazzz
Jan 15, 2010 07:17 AM
