Speedometer Issue - '92 RR
Old Apr 30, 2012 | 08:36 AM
troverman's Avatar
Default Speedometer Issue - '92 RR
Several months ago I swapped in an LT230 transfer case to replace my broken Borg Warner. I used the existing speedo drive cable and plugged it into the LT230. Everything seemed to work fine up until a couple of weeks ago. Now, the speedo either sits at zero, or generally reads way slower than it should and flutters. But, the odometer seems to work normally. I checked the cable; it seems OK. I can't see how the small speed sensor box could be bad if the odo is working? I'm really hoping not to have to replace the speedo; its expensive. Anyone have this issue?
sandnsable
Nov 24, 2011 09:32 PM
Phototone
May 3, 2008 12:15 PM
morfa
Feb 16, 2007 11:19 AM
The Mighty Finn
Jun 20, 2006 01:46 AM
lbvbroker
Mar 4, 2006 01:28 PM
