still no brakes
Old 06-26-2010, 10:15 AM
sickvehicle's Avatar
thanks scott thats the best info i got thus far... the washer in the inside is it located in the the area where the shaft is? i already took the modulator out i ordered a used one but like i said the pump was cutting on and what i did was disconnect the small line going from the pump to the modulator not the high side and i could hear a difference every time connect and disconnect the line as if the pump was coming under load when i connected it
it back to the fluid line?
Old 06-26-2010, 09:41 PM
LRScott's Avatar
It will naturally sound like its under load when connected to the modulator. The main question here is, does the pump ever turn off?
Old 06-27-2010, 05:40 AM
pump stays on i had to unplug it
Old 06-30-2010, 11:41 PM
varianted's Avatar
save your money for the repairs when it breaks down.
Muscle Max XL
Old 07-02-2010, 11:02 PM
Default fixed it
bad modulator.....go figure thanks to all u guys for the info
Old 07-03-2010, 02:13 AM
LRScott's Avatar
Most likely due to the bad plastic valve. I can feel my pedal clicking, so it looks like I might be tearing it apart one weekend.
Old 07-04-2010, 01:13 PM
Default mod
can u make some photos of the brake down i want to rebuild my old one
lrsmith62
08-24-2012 08:24 AM
FightOnUSC79
11-26-2010 09:43 AM
1eyescooter
02-01-2007 11:12 AM
Bene
01-29-2007 12:59 AM
1eyescooter
01-15-2007 08:48 PM
Quick Reply: still no brakes
