Truck parked for over 3 months...
Old Dec 14, 2005 | 03:31 AM
Rob V.'s Avatar
Default Truck parked for over 3 months...
Hi everyone, im a newbie here and here's my first post: My 2002 Range Rover 4.6 has been in a garage for over 3 months, i will be getting it out shortly. What i want to know is, are there any components or possible malfunctions that i should look out for? Should i change all the fluid by flushing and replacing? Battery? Anything? Please reply even if not sure as i would like to hear all possibilities. Thanks in advance. P.S The truck was in perfect running condition before i parked it and i did not make any special preparations either as in hooking up a rechargeable battery and that sort.
Old Dec 14, 2005 | 01:27 PM
teamyonex's Avatar
Default RE: Truck parked for over 3 months...
Check the fluids and check for leaks. Three months is not long at all, in my opinion. Crank it!
Old Dec 16, 2005 | 12:59 PM
samsly's Avatar
Actually three months is enough time for anything to happen. I suggest you take it in to a shop and have them check it for you. I had mine seating at for 2 months, when I started it blue smoke was coming from tailpipe, I ended getting a tune up, oil change, air filter change etc... also make sure you have muffler checked.
Old Dec 16, 2005 | 01:27 PM
05LandRover's Avatar
if it is a 2002, shouldn't it still have a warranty? or have you voided that warranty? Miles?
Old Dec 16, 2005 | 09:48 PM
cterrebonne's Avatar
if it would be me i would top the tank off with 93 and put an injector cleaner in the tank, crank her up let her get warm....change oil, oil filter..and check fluid levels like teamyonex said ....since you have fuel injection its a closed system unlike a carb set up therefore you should not have had any fuel evaporate causing left behind residue. im sure it also has hydrulic lifters so if you hear some knocking and it goes away after a couple of minutes i wouldn't worry about it. my 2 cents.
Old Dec 17, 2005 | 01:50 AM
Rob V.'s Avatar
Yeah i still have warranty and that's the first place i am taking it to. As for the fuel suggestion of putting fuel injector in there, which one? how do i get? I've always used 93oct. on her too.
Old Dec 17, 2005 | 03:13 PM
mikemeyer0's Avatar
check the coolant, oil, all the fluids then just fire it up let it warm up for a good bit. 3 months of sitting is not a long time, it will be fine, also go fill it up with a full tank, the gas shouldent be bad but it is not in its best state either.
SolbergFanBoi
Mar 5, 2012 07:05 PM
nahtanoj
Nov 4, 2011 09:26 PM
ragejb
Apr 9, 2007 09:23 PM
Rob V.
Dec 14, 2005 03:27 AM
SoCal Blue
Apr 7, 2005 08:59 PM
