Wheel axle spun bearings?
Old Aug 19, 2006 | 10:37 PM
sanmigmike's Avatar
7th Gear
Default Wheel axle spun bearings?
Doing the brakes on a 95 Range Rover Classic and on the rear the left rear stub axle has a little lip on it, on the outboard side. I would guess that bearing has spun. I assume that we have to replace that stub axle and that set of bearings? What size are those axle nuts? I think a bit bigger socket is needed than I have...LOL.
Anything else I need for the usual brake job? I have rotors, brakes, bearing seals, there was no gasket/seal on the axle to hub?? Some parts pictures show a gasket?
Old Aug 24, 2006 | 03:37 PM
sanmigmike's Avatar
7th Gear
Default RE: Wheel axle spun bearings?
Went by a local non dealer shop and have most of what I need. He said to use Loctite515 to replace the paper gaskets. Heck of a time finding it but while looking for it I noticed that Loctite makes some bearing compounds. Since seeing a pile of stub axles with spun bearing marks on them makes me wonder if there is some problem with either how people are installing the bearings or something else...has anyone used any of the loctite or other brand bearing compounds, some are for press fit but some seem to be for roller bearings?
ImQuattro
Apr 1, 2014 01:59 PM
cationmoted
Oct 19, 2012 07:39 AM
STLROVER1981
Jan 14, 2011 06:10 PM
zracin
Mar 23, 2008 09:26 AM
DISCOHAITI
Aug 27, 2007 09:09 AM
