Sponsored by: CARiD
00 diso 2
Old Nov 26, 2014 | 04:32 PM
Iridecbr's Avatar
Default 00 diso 2
I just bought a 2000 discovery 2 and I have several questions. Forgive me ahead of time because I don't know the first thing about these vehicles besides the fact that I've always wanted one. Here are my issues.
Leaking around valve covers. I'm aware of how to fix just looking for any tips on this one.
Vehicle will run fine once it's running and will start fine but once it's started it wants to shut off almost immediately unless you give it a little gas. Once you do it will Souter for roughly 5 seconds then idle fine
Windows don't work but I can hear the motors turning. Where is the best place you guys have found to order these parts?
Las and most importantly are these things always in four high? I feel like this should be an obvious answer but mine won't run out of 4h
Thank you all ahead of time for your time and concern.
Old Nov 26, 2014 | 04:45 PM
abran's Avatar
Valve covers: Tighten the outer bolts(2 of them on each side) with an 8MM 12 point socket(1/4 drive is best as its small enough to clear the covers). If you decide to re do the gaskets use "Right Stuff", thin layer on both sides of the gasket.
Idling: No idea
Rovers North, Lucky 8, Atlantic British. You need a window regulator, yours are broken(at least the wheels on them are).
You should only have hi and lo option. It should be in hi option when driving normal, lo option when climbing vertical terrain, Towing a stuck friend out of a ditch, or if you just like to go really slow.
In the future post in the Discovery 2 section.
Old Nov 26, 2014 | 06:17 PM
Iridecbr's Avatar
Awesome. Also there is a whining that sounds like power steering but it's not. It fluctuates with the rpms but it's the same pitch.
Also with the body and interior both an 8/10 do you think 1800 was a bad price to pay? Thanks again.
Side note: can somebody move this to the right place?
Old Nov 26, 2014 | 08:07 PM
abran's Avatar
Could be your front driveshaft.
aarons02
May 25, 2011 06:51 PM
dhaselhorst
May 20, 2010 09:57 AM
666
May 15, 2009 08:04 PM
xadamx
Jan 21, 2007 02:52 PM
tbesselman
Nov 6, 2006 02:42 PM
