Sponsored by: CARiD
1998 Land Rover discovery Passenger door will not unlock,
Old Jun 17, 2015 | 09:07 PM
RTacc's Avatar
7th Gear
Exclamation 1998 Land Rover discovery Passenger door will not unlock,
I cannot open unlock the passanger side door. all other doors unlatch no problem, but I cannot manually or electronically unlock the passenger side. Anyone know how to get it open? i don't hear any motor noise coming from that door ? please help,I really don't want to bring it to LRDealer....
Old Jun 18, 2015 | 04:57 AM
jimvw57's Avatar
sounds like the lock linkage may have come apart.might have to remove the panel and see what happened. Not sure you can do that with the door closed.
Old Jun 18, 2015 | 07:14 AM
user440's Avatar
How are you trying to manually unlock? Pulling the plunger won't work, you need to pull the inside door handle to unlock.
Old Jun 18, 2015 | 10:56 AM
RTacc's Avatar
7th Gear
hi Mike I tried pulling the door handle from inside nothing seems to release the latch I tried lifting the Open Close button I tried the remote I don't even hear any noise coming from that door all of the doors open up no problem how do I get the door unlatched with it closed and locked as it is do I have to somehow damage the mechanism inside the door
Old Jun 18, 2015 | 10:59 AM
RTacc's Avatar
7th Gear
hi Mike I tried pulling the door handle from inside nothing seems to release the latch I tried lifting the Open Close button I tried the remote I don't even hear any noise coming from that door all of the doors open up no problem how do I get the door unlatched with it closed and locked as it is do I have to somehow damage the mechanism inside the door.are the two front doors on the same fuse someone told me it sounds like its in super lock I don't understand what Superlock would be if only one door locks. thank you
Old Jun 23, 2015 | 06:32 PM
abran's Avatar
Have you tried pulling up on the lock plunger while pulling on the inner door handle? Also helps to have someone on the outside pulling on the door handle while you do this.
If that fails, move the seat to the furthest back position and also recline the back as far as possible.
Take of the door panel and study the mechanism. You can release it from the inside.
Good luck.
Old Jun 24, 2015 | 04:26 PM
RTacc's Avatar
7th Gear
Thank. You I was able to get the panel off and finally open door. ,it looks as though the actuator is not working and part of the linkage has come apart not to sure why both problems at the same time ?
Old Jun 25, 2015 | 09:37 PM
abran's Avatar
Better than 2 problems in completely different doors!
They are probably related, rarely are there any coincidences.
Old Sep 22, 2015 | 04:12 PM
RTacc's Avatar
7th Gear
Sorry it took so longto get back to you but it was the door motor that was bad and it stuck and it caused it to rip the linkage off thank you for the help though
ricariane
Nov 29, 2012 03:07 PM
canbuster
Nov 9, 2009 06:54 PM
seamuspg
Sep 18, 2009 05:59 PM
richierichrover
May 27, 2009 09:42 PM
CL_Reatta
Jul 3, 2007 12:00 AM
