Sponsored by: CARiD
2000 dis 2 pulling engine
Old Feb 17, 2015 | 05:44 PM
butchereric's Avatar
3rd Gear
Default 2000 dis 2 pulling engine
I am down to pulling engine out. all 12 bolts out, 4 from torque convert out
lift is on. jack is under gearbox . should come out
what is the trick to release engine from gearbox. shaking it, pulling it, just won't seem to come out
thanks
Old Feb 17, 2015 | 11:21 PM
abran's Avatar
They normally come apart easily. I can't remember the bolt count, but I would check again around the bell housing.
Old Feb 18, 2015 | 06:25 AM
drowssap's Avatar
there are to hinden bolt up in the bell housing up from the bottom that the RAVE does not mention.
Old Feb 18, 2015 | 03:15 PM
3rd Gear
this one has got me stuck, all bolts out according to S.M. 2 more hidden bolts not in S.M.??? I got the 2 bolts facing up in the bell. on the very bottom as part of the 12 removed. Where exactly are the secret bolts located that are not in the S.M. this baby won't come out.
Old Feb 18, 2015 | 05:47 PM
lordmorpheus's Avatar
I went out in my garage and counted 8 threaded openings on the block itself, and 6 un-threaded holes on the oil pan.
If that helps at all...
Old Feb 19, 2015 | 05:33 PM
3rd Gear
thanks guys, engine is out. drowssap you are right. I had the 2 bolts already out you talked about and counted them in the 12 the s.m. says to remove, there is 12 in the bell, and 2 more not mentioned. comes out a lot more easy with all the bolts out. ahh
cheers, thanks
Old Feb 19, 2015 | 06:27 PM
drowssap's Avatar
Guess how I know
cheezer12
Dec 19, 2011 10:27 AM
benslandrover
Sep 4, 2008 08:57 AM
fortworthcoe
Jun 4, 2008 06:39 PM
fortworthcoe
Jun 2, 2008 05:47 PM
kcirtap
Oct 12, 2007 08:32 AM
