Sponsored by: CARiD
2000 Disco II Noise when accelerate
Old Sep 13, 2007 | 11:04 AM
haRley C.'s Avatar
3rd Gear
Default 2000 Disco II Noise when accelerate
I have a 2000 Disco II, when I decelerate while cruising at speed and then step back on the gas there is a noise. It does not happen while driving slow; only seems to happen over 50 MPH. I have checked the universal joints and drive shafts, everything appears to be good and tight. It only happens while at speed and I can not replicate it while its jacked up. It sounds like its coming from the transfer case, but I'm unsure because I can only hear it while I'm driving the vehicle.
Any one have the same problem or know what is causing this?
Thanks,
haRley C.
Old Sep 13, 2007 | 12:16 PM
Default RE: 2000 Disco II Noise when accelerate
Are you talking about a clunking sound, if so it is normal. How long has it been since you changed the t/case oil? Might want to switch to 85W/140 it will help keep the t/case noise down.
msilverman239
Aug 2, 2024 08:37 AM
LuckyEagle77
Jan 22, 2015 01:41 PM
bcolins
Jan 21, 2014 07:37 AM
mirko_gardilcic
22
Nov 3, 2009 10:49 AM
Discodude
Jul 21, 2009 08:19 PM
