Sponsored by: CARiD
2001 Dicovery bearing noise?
Old Dec 19, 2011 | 09:11 AM
Keef's Avatar
Default 2001 Dicovery bearing noise?
My '01 DII has a noise (kind of a rubbing sound) coming from the driver's side while driving. I cannot tell if it's coming from the front or rear. Sounds like in between sometimes. Is there some other bearing that might be going bad other than the wheels on the driver's side?
Old Dec 19, 2011 | 10:35 AM
Sometimes it helps to locate a long brick wall that you can drive by at slow speed, in a quiet area, with windows down.
Sometimes you can have someone drive the car past you several times.
Sometimes you can put car on a lift or on jackstands and run it at slow speed, turn wheels, etc.
Sometimes you can slip the car into "N" and coast to rule out some engine parts.
If a "ticking" sound might be flex plate between tranny and engine.
Sometimes it is brake pads or calipers that make stange noises, usually a screech when applied. Could be a dust shield bent by contact with something.
There are lots of things that you need to narrow it down from.
Old Dec 19, 2011 | 05:55 PM
Have your front driveshaft inspected for play.
If it breaks it WILL destroy your transmission.
Grlica
May 1, 2013 06:13 PM
sayeedA
Nov 28, 2011 01:01 PM
TOBY
Dec 7, 2006 01:23 PM
Whitesands
Mar 22, 2006 01:13 AM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
