Sponsored by: CARiD
2001 disco 2 induction instructions
Old Feb 22, 2010 | 09:46 PM
noahsfortune's Avatar
Default 2001 disco 2 induction instructions
Anyone have the link to the induction instructions for the disco 2? I looked high and low. I have a 2001, with 98000 and its and SE. Thanks again for all your help.
Old Feb 23, 2010 | 11:48 AM
yloDiscoII's Avatar
Are you looking for instructions for the induction cleaning??
Old Feb 23, 2010 | 04:15 PM
Thumbs down
yes please. Induction cleaning. I cant seem to find it.
Old Feb 23, 2010 | 05:30 PM
yloDiscoII's Avatar
I don't know if there are any detailed directions spelled out anywhere here recently for a DII. I did this a couple weeks ago on mine and it's easy.
You'll need a couple feet of vacuum tubing (unsure of the diameter) and I used a pair of needle nose pliers as my clamps to regulate the flow of Seafoam into the IM.
Disconnect the hose BELOW the hose with the red washer and connect your tubing up to that nozzle. The other end of that tubing will go into the Seafoam.
The rest is just like the other posts regarding the induction cleaning. Take your time drawing the Seafoam out of the can, it should take you around 5 minutes or so for the full can, use the pliers to regulate the flow. After the can is empty, shut off the engine and let it sit for 30 minutes. This is a good time to clean your out throttle body. After the 30 minutes is up, start it up and rev up the engine or drive like a crazy person around the neighborhood.
I did mine at night and was lucky enough for it to be foggy and my neighbors were gone, because it WILL smoke
Old Feb 23, 2010 | 10:39 PM
WARWAGON's Avatar
Once its hot You can actually use water too. Look at how a blown head gasket cleans the tops of the pistons and the head.
Old Feb 24, 2010 | 10:42 AM
hilltoppersx's Avatar
i used an adjustable so i could go start the truck without holding the needle nose, and the tubing is 3/8"
Old Feb 24, 2010 | 10:45 AM
yloDiscoII's Avatar
Water instead of Seafoam??? I guess this be similar in principal to microwaving a cup of water to loosen all the spaghetti sauce and soup stuck to the walls on the inside??
Now I'm curious, have you ever tried this? Using water instead of Seafoam I mean, not blowing your head gasket to just clean you pistons?
Old Feb 24, 2010 | 01:06 PM
WARWAGON's Avatar
I've done it with water. As for does it work? That I do not know. I've never had anything apart before and after i've ran any cleaners or water through the engine. I just use the theory that when coolant/water gets in man does it clean stuff. But who knows? I guess if ya have a borescope you could check before and after.
Old Feb 25, 2010 | 11:40 AM
yloDiscoII's Avatar
Got the engine nice and hot and tried it last night with water, tripped some codes, but they disapeared before I could get them read. Hopefully my insides are just a little cleaner now!
Old Feb 25, 2010 | 03:11 PM
WARWAGON's Avatar
Yeah the missfire monitor goes crazy. You probably had a bunch of miss fire codes. It's all good!
acg
Mar 17, 2014 05:48 PM
WhackdNegypt
Mar 5, 2012 10:44 AM
bfre49849
Aug 9, 2011 01:19 PM
BayouDisco
Audio/Visual Electronics
Dec 16, 2008 12:26 AM
Phototone
May 11, 2008 12:13 PM
