Sponsored by: CARiD
2001 Discovery II fuel management
Old Feb 11, 2008 | 11:58 AM
tophur's Avatar
Default 2001 Discovery II fuel management
What is the effect of pulling the plug on the inertia fuel cut off switch? Does that JUST dissengage the fuel pump, or does it also effect the ECU?
If it does effect the ECU, what are the effects? What is the most efficient way to dissengage the fuel pump without effecting the fuel injetors, ignition and the ECU?
Old Feb 11, 2008 | 03:23 PM
WolfPack's Avatar
Default RE: 2001 Discovery II fuel management
I would guess pulling the fuel pump relay possibly..I'm not entirely sure though if that leaves injectors and ignition in working order.
Old Feb 11, 2008 | 06:26 PM
Why would you want to remove the switch?????????????
Benhuddle
Apr 11, 2014 01:42 AM
KigomaSteve
Apr 15, 2013 12:55 AM
Savannah Buzz
Feb 28, 2013 07:47 AM
eaglewing
Jun 2, 2010 11:05 AM
